What are you wanting ?
My 38 lightning also has no drain holes where you are pointing. Really no way for water to get in there, it is a sealed box with fuel tanks. The drains above (in your pic) are actually pipes under the floor that run to the basin on the front side of the gun wale. I have another set of outlets that drain close to the sides that are hooked to the floor drains and under seat drains.
Originally Posted by Louie
(Post 4131309)
Would someone take a look in their boat for me?
Mine has 2 glassed-in PVC pipes. I'm pretty sure one goes to the floor drain in the cabin. Not sure what the other one is for.
My old Chaparral had holes in that area leading to the fuel tank compartment. When my fuel tank started leaking, I knew abt it. |
Originally Posted by zz28zz
(Post 4132394)
Originally Posted by 575cat
(Post 4132605)
What are the odd,s that the pvc and glass are bonded good and not leaking water around it ? I don,t think you would want to know what that fuel tank cavity looks like .
I'd bet money the fuel tank cavity is in fine shape on this particular boat.:D |
(Post 4132621)
Judging from the build quality of the boat in general, I'd say the odds are pretty good that it's sealed tight.
| All times are GMT -5. The time now is 10:41 AM. |
