-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   A/C air conditioning removal (https://www.offshoreonly.com/forums/fountain/313116-c-air-conditioning-removal.html)
FIVEPTOHH 06-01-2014 09:14 AM
Looking for the best way to plug or block off the port next to the drain plug on the back of my boat. I am assuming that the port is where the air conditioning sucks in water. I have removed the air conditioning from my boat and just want to make sure that I block that opening off......any suggestions.?
whiskeyhangover 06-22-2014 08:32 PM
Anything wrong with it? If not,
Do you want to sell it?
dewayne6243 06-23-2014 09:21 AM
Just had mine done. Fiberglass guy glassed it and gel coated the holes.
FIVEPTOHH 06-25-2014 08:32 PM
I was told it needed a charge of Freon. I keep my boat on a airdock boat lift so the A/C is really of no use to me. I have the part of the system that is mounted in the engine compartment. I would sell it if you are interested. I would imagine it will not be cheap to ship.. Throw me a offer and I will take it out.
FIVEPTOHH 07-12-2014 03:52 PM
OK I removed the air conditioning from the engine compartment. I was also able to remove the wiring that goes into it. I also removed the pump that was inline to it. Any takers..? Not sure if it works or not. I will sell it cheap
Bawana 07-18-2014 01:00 AM
text me some pics 920-475-0852. I might have a home for it
