98 32 fever
which lower would you install a -1 or a -2 ...with supercharged 502 hp
Hay Boy I have a 96 with -2 imco lowers 615 hp each runs great with bravo 30 pitch 90 at 5600 rpm
Rich |
the 98 32 had the large step compared to previous years. -1 lower may be better to run. you may have to run 5 blades and have planning issues with the -2 lower on that year hull
Mine is a 2000 model with 565hp, -2 shortys and 5blade hydros. Runs mid to upper 80s and jumps right up on plane no problem
Chris |
With 5 blades they run good But many will agree 5 blade props tend to eat bravos for breakfast
thanks for the info ...I have heard that maximus props are hard on bravos also....
99 32, -2's, 800hp 900ft# 34" maximus. perfect. If you go with -1 I have some labbed 36" bravo's I need to sell if you think you can turn them. With -2 you need 5 blades.
| All times are GMT -5. The time now is 07:24 AM. |
