-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   29 fever seats (https://www.offshoreonly.com/forums/fountain/316340-29-fever-seats.html)
57chevymike 08-04-2014 03:58 PM
29 fever seats
how are the seats bolted down on a 2005 fountain fever.........drivers seat bolt is loose and i would like to hear from someone that replaceed their seat ...............thanks 815 236 3086
carcommander 08-05-2014 10:09 AM
On my 27 the bolts are just lag bolts. I took a hole saw carefully cut a 6" hole , remember the fuel tank is under there, and then thru bolted it. Worked like a champ.
57chevymike 01-12-2015 02:43 PM
thanks did that under my swim deck in order to mount pull out ladder it also worked out sweet...blew a water impeller back flushed and still having water pressure problems pulled the cmi headers will rebuild over winter attempting to figure out the factory recall on water flow .....I'm in the process of designing a back flush set up with water and air valves......................thanks mike 815 236 3086
