-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   1988 29 Fountain power question (https://www.offshoreonly.com/forums/fountain/319947-1988-29-fountain-power-question.html)
jackieboy 11-07-2014 02:09 PM
A friend of mine just purchased an 88 29 Fountain. My question is does anyone know of anyone with a 29 with HP 500's, and if so what we're the performance numbers such as speed at 3000 rpm's, 3500 rpm's and top end. The boat now has stock 330's in it. If not HP'S something close to it. Would be interested in knowing what size props also.
88Fountain 11-10-2014 07:30 AM
My twin 27 (29) Fountain came with 454/365 mag engines and it ran 76 on the pitot tube speedo, which turned out to be 72 on a GPS I got later. This is with Bravo 1 drives with nose cones and 14 1/2" x 26 pitch 3 blade Spinelli props.
ezstriper 01-02-2015 03:45 PM
Friend of mine had a 98 with 454EFI's would run about 82 if all the planets were alinged and your balls were big enough...could get unruly in a hurry....in my opinion they are great 75 mph boats...and many run faster...some have run 100+ but overall you better know what you are doing..understood, reggie 1st dropped the 502EFI option, then the twin B/B all together...why you see many later model ones with twin S/B's..so to answer your question..I have never seen a twin 500HP 29...not to say they never made any...
fordf350 01-02-2015 11:50 PM
jackieboy; Clear out your inbox and I wil PM you someone that dropped 500s in his boat two years ago
EdJ322013 01-04-2015 09:05 AM
My 29 with stock 365s BB ran 68gps with four blade finished props 24p @ 4800. We are in process of bumping the power a bit so I am hoping to be able to turn 26p. Installing steering asap, as it can get hairy quickly!
EdJ322013 01-04-2015 09:12 AM
I would love to get more info on the fever with hp500s....
88Fountain 01-04-2015 11:47 AM
Installing full hydraulic steering is a good idea, don't get me wrong, but it is still going to be hairy. I was going to have Reggie III do some work on my boat and he suggested just tightening up the slack in my cable steering. I have always read on OSO about how full hydraulic steering was needed. I didn't want to put a bunch of money into rebuilding/tightening up my cable steering and still have to go full hydraulic anyways. I ended going with someone else to do rigging and painting on my boat. One of the things I wanted done was full hydraulic steering. Full hydraulic steering made absolutely no difference on my boat. It is still a white knuckle ride once you get over 80. In fact, I hardly ever get it up to that speed because it chine walks so bad. I have not had very much success "steering" out of it either.
Wildman_grafix 01-05-2015 02:49 PM
Try dropping you tabs just a little. My 32 doesn't like them above level, and I see no speed loss.
EdJ322013 01-06-2015 05:57 PM
The steering is more for safety, if that steering cable breaks everyone in the boat probably won't be in the boat very long, at least with hydraulic steering, if the pump fails you can still steer, it won't be fun but it's possible. As for the chine walking, hydraulic steering might hurt due to zero slop in the steering, but I haven't experienced it yet so that's just a guess. I have heard of doing the tabs, and have read of guys installing 380 k planes, and that seems to help a bunch. I don't know if I want to trim the 380s though to clear the drives... I may change my mind if it is terrible chine walking though! Depends on the terror face my dad has if it starts walking. What speed is the worst or egged did it start walking?
LKNCOBALT 01-06-2015 07:56 PM
I would think a 29 with twin 500s would be floating the sun deck with all that weight! Fast boat for sure on the throttles.
