Weight of 29 Fever w/ Twin Scorps - Is Performance Sheet wet or dry?
Does anyone know if the weight listed on the performance sheet from Fountain is the dry weight? Or is that the wet weight the day of the test?
I know a single big block 2004 29' weighs 5500 - 5850 dry. My boat has the twin 377 Scorpion motors. So subtract a little bit of weight for the small block, add some weight for the 2nd small block and outdrive and you're at?
Performance sheet lists the weight at 6660. Also says the boat was tested with 60 gallons of fuel. Can anyone confirm?
Hi ! I had the same boat and engines! Mine ran 82. I never actually weighed it. Do you have some pictures of it? Here are a gallery of mine http://www.playmarine.no/albumview.asp?albumID=223 MISS THAT BOAT..................
Ours would run 84 on a really good day. High 70's every day.
Needs some transom work now and is for sale for a few more days until I decide to do the work and keep it: http://austin.craigslist.org/boa/4854088034.html
