anyone try drive spacers to lower slip on a 42 700 #6 boat ? >
Old 02-24-2015, 05:33 PM
Default anyone try drive spacers to lower slip on a 42 700 #6 boat ?
Anyone have any info on the effect on using drive spacer's to lower slip factor with this package ? Hull is an 07 700 #6 . Thanks
notda1 is offline
Old 02-26-2015, 10:42 AM
Kelly O's Avatar
PM gnorthga here on OSO, he put spacers in his 42/700/6 boat. Not sure how much he's here anymore.......probably frequents the cruiser forums doing reviews of dinner and wine selection pairings. LOL
The 42 you have needs to be spaced just a little lower, seems you can demo spacers now to try before you buy from BBlades. Nice purchase, no expense spared to keep that one tip-top mechanically.
Kelly O is offline
Old 02-26-2015, 05:19 PM
Thanks for the tip , I'll give BBlades a call . Sounds like a common problem , seems like a simple solution . Probably not that easy though ........
notda1 is offline
Old 02-28-2015, 06:49 PM
The boats come really well set up and there is not a lot to gain. I have a set of 1/2 inch and custom made 1/4 spacers for sale that I do not need anymore since I have sold my boat. I found that the difference is really in how the boats attitude is in the water and found that the boat was maybe a better pleasure boat for just cruising and changed the handling at wide open some with the spacers in. It did not change the top speed or from what I could tell prop slip. I also must add that this was on a 38 Lightning not a 42. FWIW I ran no spacers to run in the LOTO Shootout to get my best speeds. I have the spacers, tubes, studs and gaskets if you are interested. Al @ 219 670-0082
ARB38 is offline
