-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Fountain warning lights and alarms (https://www.offshoreonly.com/forums/fountain/325105-fountain-warning-lights-alarms.html)
Drew555 04-13-2015 07:40 PM
So I just rebuilt everything on my 35. From motors to drives all new. So I figure to protect my investments I would look into why my alarms are not sounding with the key in the on position but the warning lights would go on. Well after taking the helm apart I found old owner cut the alarm wires. I guess the noise was hurting his time on the water while killing the motors.( dumb ass). But as I was digging deeper I noticed that the port warning light was twined with the starboard side.. So I looked it up in the fountain wiring diagram and it was wired that way from the factory. So I guess my question to fellow fountain owners why would anyone put 2) warning light in a dash clearly market port and starboard and just twin them together . Makes no sense to me. How would you know where the trouble is. And why 2) lights. So my answer is cut it all out and start over. This way I know what motor I'm having a problem with right away. Anyone else do the same?
Cole2534 04-13-2015 07:55 PM
Lights because the alarm gets your attention and the light helps diagnose.
I don't understand why they'd be wired common, but wiring schematics are not always the easiest to digest. Perhaps you missed a detail?
Drew555 04-13-2015 08:09 PM
Not at all . You can look on the fountain web sight and look yourself. It's right there. I understand the lights and alarms but why would you twin two lights together .
Drew555 04-13-2015 08:16 PM
[IMG]http://i46.photobucket.com/albums/f1...ps7w5cf5aw.jpg[/IMG]
Drew555 04-13-2015 08:17 PM
You can see where it says "engine lights" clearly it shows them tied together
US1 Fountain 04-13-2015 08:54 PM
I 'fixed' mine. Didn't like both lites lit up, and trying to see which motor had died, while trying to dock. The indicator lights are now totally independent of each other as they should, yet the alarm still sounds when either motor dies. A simple fix with a couple diodes.
Drew555 04-13-2015 09:00 PM
Already on it
joew. 04-14-2015 09:20 AM
Mine is wired the same way. If an issue shows up, both lights come on. Maybe the benefit is twice the notification for a single problem? If the boat is over trimmed and hitting the limiters it may be for difficult to see one light or hear one buzzer? Probably just easier for the factory this way though:) Good question because I thought mine was messed up.
