-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Thru Transom or Thru HUll (https://www.offshoreonly.com/forums/fountain/328959-thru-transom-thru-hull.html)
682gold 07-27-2015 05:15 AM
I have a 2000 38 Lightning w/ small steps. I want to get away from my drives being my water pickups. Have any of you changed and where did you place your new water pickups?
green lightning 07-27-2015 11:21 PM
I asked the same question a few weeks ago and nobody responded , so I picked up a pair of adjustable pick-up's and mounted them right next the drain plug as soon as I finish putting it together I will let you how it works
682gold 07-28-2015 07:24 AM
Look forward to hearing how it went. I am leaning towards the thru hull. The notched transom is proving interesting to work with. I have plenty of room in from of my engines to work with and can get them pretty close to the end of the running surface.
green lightning 07-28-2015 02:59 PM
That is why I went with the adjustable ones , so I can try to get the water pressure where I want it
