-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Prop size 27 fever (https://www.offshoreonly.com/forums/fountain/331529-prop-size-27-fever.html)
47 lightning 10-11-2015 12:53 PM
Prop size 27 fever
I have a 1995 - 27 fountain fever-single step with a 502 mag-415hp-bravo 1- 1.50 ratio. Looking for information on prop size,pitch and rotation. All i have on hand are 2 - 27 pitch-4 blade hydromotive -left and right-that i am going to try on it. I know its to much pitch, but going to try it with that. Any info would be appreciated.
Unlimited jd 10-11-2015 01:52 PM
I'd say a 24 bravo 1, I have one at the shop with a 500efi and he's able to spin that to 52-5300
47 lightning 10-11-2015 03:33 PM
Is it a rh or lh and at what speed?
ALL_IN! 10-12-2015 07:39 AM
My old 2000 27 Fever had a RH 24 Bravo I on it, and it seemed to be the perfect prop. With that said, I had not heard of any other 27's with a RH prop. Most are LH.
Unlimited jd 10-12-2015 07:55 AM
73, right hand prop
chaoscube 10-16-2015 08:54 AM
26P RH 4 blades Cutting Edge here on a 27' non stepped with 520hp ...Bravo 1 24P RH on your setup should be the best
speedfever 10-18-2015 08:18 PM
I had a 2000 fountain 27' 502 mag, 23p hydromotive, lh. Ran 67mph on gps at 4950 rpm. Bblades labbed a 24p bravo 1, lh, it got me out of the hole better, had good cruise performance and got me 70-71 mph at 5150 rpm.
