WOT Issues
Used my boat 2.5 weeks ago for a poker run and ran great. I was getting about 5100 rpm or so at WOT on both motors. I decided to do some maintenance work on the motors and changed the oil and spark plugs on both motors. Take the boat out last Thursday to test and all of a sudden I can't get over 4000 rpm at WOT on both motors. Pulled boat out the water and put on hose to flush out motors and while flushing each individually I revved the motors and each got over 5000 rpm. All plug wires seems to be on correctly and tight. What could be the possible issue why they all of a sudden won't turn over 4000 rpm with a load on them?
A rule of thumb, if something is working then you mess with it and it doesn't work.
Re check everything you just did. Plugs gaped right, maybe a bad one. Put the wires on wrong. Etc. |
I'm pretty sure all wires are correct because they are set at a length that only reaches each spark plug specifically. I'm thinking it might be a gapping issue also but why would it allow it to rev over 5000 out the water and only be able to get to 4000 in the water with a load?
It takes relatively no air and no fuel and no spark energy to rev a motor to redline in neutral. Say, 15 hp or so.
Wot is low cant go past 4000,502 mpi,1999
HELLO GUYS, I am new too the forum, i have the same problem with my 1999 sonic 260 prowler, i can't get over 4000 rpm, running great all season, but i didn't go wot all the time, got 4800 in the begining of the season and did 69 mph on a 4blade 23 revo prop. i changed the filter ,checked the anti siphon ck vlv,( which it doesn't have now from previous owner)when i go 1/2 way with throttle to 4000rpm but when i push the throttle up it just stays at 4000rpm, slight surging,and running a little rough today, seems to be getting worse. when i back off it seems to recover and smoother, no pops or backfires. pulled the plugs and they look great, BUT THE CAP AND ROTOR WERE HEAVILY CORRODED, i HOPE THAT IS MY PROBLEM! I put a vacuum to the regulator and it holds a vacuum.i took it out and beat on the boat hoping to clear it out. after i shut it down and restarted it got it up to 4400 rpm but came back down to 4000 after about 1 mile. i will put on fuel pressure gauge soon to help troubleshoot,but is there a safe mode or a rev limiter on these engines, thanks in advance DINOKOS
Rev it up to 5K or better out of the water with no load, who's brainstorm was that. You can do all kinds of bad chit with that.
Like said above if all was well before you masterminded it, then go back thru everything you did. Your problem is in there. |
Originally Posted by raggededge
(Post 4497868)
rev it up to 5k or better out of the water with no load, who's brainstorm was that. You can do all kinds of bad chit with that.
| All times are GMT -5. The time now is 12:06 AM. |
