-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   out drive and prop advise (https://www.offshoreonly.com/forums/fountain/339595-out-drive-prop-advise.html)
proscapes199 07-25-2016 05:27 AM
I have a 29 fever with a 575 @ 750 hp, bought a 2 inch IMCO shorty and put it on my XR upper, tried 2 different props my original bravo 1 30 and a herring 5 blade lab finish 29 in both cases slip numbers are off the chart. Has anyone had similar issues like this? Should I put spacers on the the lower unit? What would be the best prop? Top speed so far was 83
class6 07-25-2016 05:39 AM
Does that hull have a notch?
Tinkerer 07-25-2016 07:19 AM
How far below the lowest point of the hull is your prop shaft?
Fountain's are known for high propshaft height.
You may need only a -1 shortie.
VoodooRob 07-25-2016 07:36 AM
I recall seeing you can trial different spacers from BBlades to get it right. Other larger prop shops should offer the service too.
mcprodesign 07-25-2016 09:42 AM
You should try a bravo or hydro 4 blade. A hering is a surface prop. You could also try hydro p5x if you think you want a 5 blade
proscapes199 07-26-2016 05:11 AM
Was really hoping to maybe find some one who has tried the different combo's and hear thier results
badluck 07-30-2016 01:02 AM
Not a 29 but I'm at 10% slip with a -2" Imco lower and a stock P5X on a non step 27.
Propshaft is about 2,5" below the bottom.
mcprodesign 07-30-2016 10:24 AM
I had a 27 with close to the same drive height you have. Pretty sure you are deep. You have to find out how deep the propshaft is in comparison to the bottom . X dimention . Most stock ones are close to the same but you never know if it has been changed until you measure it.
My 27 had pretty high slip compared to a surface prop. I ran pretty good with a labbed 28 bravo and i could pull a skier behind it too ( it had a blower). The hydromotive 4 blade cavatated a little . Find out you x dimention, call BBlades . ( they will let you try props for 25 bucks for a week . Otherwise you are not going to get the best numbers off of what someone says on here imo. The p5x was pretty good on my 38 until i raised the x dimention.
lslavick 07-31-2016 09:50 PM
I'm running a 29 with -1" IMCO shorty... Pushing about 640HP. My best is 82 running a 28 labbed Merc Maximus 5 blade. But, I have slung blades on 2 of them. It's getting expensive. My experience has been this: A labbed 30 Merc Bravo 4 blade likes weight. Best speed is with full tank and 5 people. The 5 blade likes it lighter. I have also tried the P5X... But, is was a 30. I think it was just a little to big. I liked the way it ran. It was not labbed. May try a 29 P5X next.
