-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   HP Needed to Achieve 90 MPH (https://www.offshoreonly.com/forums/fountain/340163-hp-needed-achieve-90-mph.html)
Esal 08-10-2016 09:03 AM
What horse power do I need to achieve 90 MPH in a 38 Fever none stepped hull?
soldier4402 08-10-2016 09:50 AM
http://www.go-fast.com/boat_speed_predictions.htm
Crude Intentions 08-10-2016 10:23 AM
Mild thunder on here hit 89 mph with 800 a side in a non stepped 38. This is with Speedmasters drives.
mcprodesign 08-13-2016 04:00 PM
You can get 10 mph out of set up. So the exact hp may be different.. My stepped 38 ran 90 when i got it . Now it will bust a hundred (without even touching a motor) . Aprox 700 hp each
Anoller 08-25-2016 05:34 PM
@mcprodesign - what size steps do you have? I have a '99 38' Fever with the small steps. With full fuel, full gear, a honker of a stereo system and my fat ass on board, I busted 92mph on a short stretch. How's yours set up? What drives? Props? Gear ratios? Ect? If I had more lake at the time, I'm sure I could have broken triple digits. I'm running 900hp/side. Side-by-side motors, small steps.
1989mach1 08-25-2016 08:42 PM
Don't forget to count the wight of the skanks and your gold chain. That some times get left out of the equation
1989mach1 08-25-2016 08:48 PM
Full tank of gas on a non stepped hull with two skanks u will need around 900hp per side
Crude Intentions 08-25-2016 09:18 PM
^^youre mistaking. I just posted Joe runs a non stepped boat. 89.6 with 800 a side. Still tweaking some things.
mcprodesign 08-26-2016 09:31 AM
Sportmaster -2 2004 gen XR drives. Have to change the oil a lot to keep them clean and healthy, but they use little HP to make the props turn. But you have 900 hp so you might need stronger drives.
I blue printed my lowers ( myself) and the bottom of my boat ( myself) and went faster. I also get 3-4 mph out of the herings over the maximus 5 blades. Our boats love 5 blades . I have tried 4 and 6 blades. 6 blades will work but hard to get on plane. Mine is also a small step 38 . I have no plumbing or kitchen. Just a porta potty in the bathroom.
mcprodesign 08-26-2016 09:41 AM
1 Attachment(s)
It's probably a little more weight forward of the cockpit having the sink and plumbing. I ran without an anchor and anything in the galley to get the bow lightest I could for speed. Hope this helps!
