Drive trim problem
I have a 32 fever that when trimming the drives in when using any of the the 4 switches (the throttle, the "both" and independent switches for drives in they move together, even with the independent switch, however when trimming out they move as they should independent or together depending on which switch is used. Any suggestions of what might cause that?
| All times are GMT -5. The time now is 09:08 PM. |
