Tv for 35 fountain
Looking to install a tv in my 02 35 lightning. Any ideas in size and how to mount it the best? Looking for a blue ray combo tv.
Thanks |
Anyone have any ideas on how to mount? I am looking at a 22 inch i think will fit on the wall right behind the bathroom facing the v birth.
I used a slim mount that tilts up, installed a 37 smart tv inch in my 405 so I could stream movies to it thru WiFi. Would not recommend an integrated blu ray player, I would recommend an over the air HD antenna. I tried to find a pic of your interior but I have no measurements, it might be cool to put it forward and have it flip down from the ceiling and face rearward just a thought.
Thats a good Idea, in the v birth by our feet maybe? Would have to be a slim tv and mount though so we don't hit it climbing to the v-birth. The dmentions on the wall I was going to use is Max 22 wide x 18 heigh prob fit a Diagonal 22 inch. But I like the flip down idea have to use smaller tv but that ok it would be a lot closer and when watch movies we are in the bed anyway.
Well started looking for a flip down but after finding a few I have no idea how I could mount that up in the vbirth, any ideas. Might go back to wall mount one if not
Thanks |
Recommend a good stereo shop come out and look at it and give you ideas. It's hard to comment because I am not looking at it.
thanks good idea
I would think you would have to pull the headliner, glass in some marine plywood to the underside of the deck, reinstall headliner, then screw (or better, through bolt prior to fiberglassing) your mount to the plywood while punching holes through headliner. I wouldn't do it if I were you. But it's your boat!
I agree, no way i would go that far I think I might just stick with a laptop lol been doing that for years anyway. Maybe spend the money on led lighting insted.,
Terry I almost made the drive to come down and buy your 35 but found one closer, however it has the same engine set up as yours and I have a couple questions you mind if I give you a call? |
Yep - call me after 5pm central. 812 - seven six zero - 5711
Originally Posted by marcusnapier
(Post 4525128)
| All times are GMT -5. The time now is 05:02 PM. |
