-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Bravo 1 - bravo x or xr (https://www.offshoreonly.com/forums/fountain/343324-bravo-1-bravo-x-xr.html)
karkatch 12-16-2016 02:21 PM
Can anyone tell me how to determine accurately whether I have Bravo 1's, X or XR's. A number of business have all told me different !
1998 MerCruiser MCM 502 MAG MPI; 415HP
Is there a site that I can input the serial numbers?
Dave at Fountain has told me they are technically XR'S, before MerCruiser started their advertising campaign and added new logo's in 99/00.
Any feedback would be appreciated.
RaggedEdge 12-16-2016 04:51 PM
likely than not with your 502 Mag MPI's you have Bravo 1's. Why, other than a real lack of smarts, anyone would tell you they are XR's is beyond me. You can take the serial numbers to any Merc dealer and they should be able to give you an answer. Lots of clues, prop shaft size? gear cut? Pull the back cap and take a look see. Pretty simple deal, no reason for any builder to hook 502 Mags up to XR's. Not saying a former owner might not have done the change.
Clustergear 12-16-2016 10:25 PM
Post the serial # on drive I can check it for you
karkatch 12-17-2016 10:57 AM
Thank you Clustergear;
Drive serial #'s
0L86936
0L18635
Clustergear 12-17-2016 03:24 PM
I think you might be missing one number. Both come back serial not found. If you can't read the numbers post engine or transom ser#. If they came with boat the number should come up under product history
class6 12-17-2016 03:33 PM
My book says standard Bravo 1,,Im saying that because I didn't see anything else made starting with OL
1989mach1 12-17-2016 03:37 PM
Didn't all xr's have the larger prop shaft? And the brovo 1 and 1xz had the 1 in
F-2 Speedy 12-17-2016 03:44 PM
XR's are 1.25 inch prop shaft
Keith Atlanta 12-17-2016 03:45 PM
Only definitive way is pull the top cap, take picture of gear teeth(its tough to get the angle but it can be done), post pictures, reassemble.
There are too many what if's on a boat over 10 years old. The part numbers tell you what it "was" - if they ever broke, who knows what was put back in.
JaayTeee 12-17-2016 04:32 PM
The X family started @ s/n OM
thirdchildhood 12-17-2016 08:48 PM
Yep. XR has straight cut gears and 1.25" prop shaft. Pull the top rear cover. It has a reusable o-ring seal.
