-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Need template - 42 with #6 - cavitation / vent tubes (https://www.offshoreonly.com/forums/fountain/343799-need-template-42-6-cavitation-vent-tubes.html)
willknotsign 01-10-2017 08:26 PM
2 Attachment(s)
Here's a few pictures of my 42' Fountain.
adrenalinejunkey 01-10-2017 09:34 PM
Might be a dump question but what gains did you see on your 42 by adding them and what do you have for power?
575cat 01-11-2017 08:25 AM
Yes those are smaller than mine , they also make good drink holders , 3 inch ID .
adrenalinejunkey 01-18-2017 12:29 AM
ALL_IN! 01-18-2017 07:32 AM
Yeah - Reggies picture shows flange about 4 3/4" away from gear case. I did not measure the flange diameter on mine (however).
Originally Posted by 575cat (Post 4518305)
If you look @ Teagues web site or I can text you a pic , your drive setup should be the same as my 38 very minimal tilt bur they do not hit about couple inches away from platform . Mine are quite a bit bigger than you show there flange is 1.5 away from upper housing 5 inch flange with 3 inch hose .
ALL_IN! 01-18-2017 07:33 AM
Yours look closer to what 575cat is saying, as far as location. Am I seeing that correctly?
ALL_IN! 01-18-2017 07:35 AM
If you are asking me, they help the prop cavitate to aid in getting the boat on plane (with BIG F'n props). I've got 700's.
575cat 01-18-2017 11:47 AM
Being a 700 boat and yours did not come with vent tubes with 6 blades ?
willknotsign 01-18-2017 09:52 PM
When I bought the boat they were already installed. It does come up on plane quickly. I wouldn't expect any increase in top speed.
willknotsign 01-18-2017 09:54 PM
I can get you measurements this weekend.
