-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Prop Help (https://www.offshoreonly.com/forums/fountain/348330-prop-help.html)
Jmuro 07-11-2017 01:05 PM
Prop Help
hey guys hope someone can point me in the right direction. Need help on getting my fountain dialled in prop wise .
1992 27' flat bottom fountain
650Hp @5500-5500rpm
Standard Bravo one 1:50
Right now I'm running the 4 blade hydromotive 24p and running 5600-5700rpm with trim still left .
What do you guy suggest would be ideal prop for my application?
Any info or advice would be greatly appreciated
Thanks Joe jr.
Eliminated572 07-11-2017 01:12 PM
Try a 26p Bravo. A bit better bow lifter I am told vs the 4 blade hydro... Unless you are fine with how it acts, then simply raise pitch 2" or so.
Padraig 07-11-2017 01:32 PM
Yes, 24 seems a little on the low side.
Padraig
Jmuro 07-11-2017 09:03 PM
I really like the hydromotive , what would be best size going that route
Eliminated572 07-11-2017 10:23 PM
Depends on the desired RPM change. Every inch of pitch is approx 200rpm. So, if you want to drop RPM by say 300-400, raise pitch number by 2".
