Hydraulic Steering Issues
I've got an odd issue that I've been dealing with since buying the boat last year. 02 35 Lightning and the hydraulic steering gets super stiff the hotter it is outside (as in the outside ambient temperature). When I first got it I just thought the steering went out but then the next morning it worked again. So morning it works fine but as the day goes on and gets hotter, the steering gets harder and harder and then in the late afternoon/early evening when the temp starts to drop it starts "working" better and better. Mind you I'm not running the boat any different in those late afternoon early evening runs (truth be said, I tend to run the boat harder at end of the day to either burn gas, make it in before dark, just enjoying the best part of the boating day, or all above). It seems to be at its worst when it reaches about 85 degrees and above outside. Anything below that it works just fine, so early in the season where temps don't even reach that high I have no issues all day. Hydraulic oil is at the proper level. I might be crazy in correlating the outside temp, but it's the only pattern I've been able to establish that reproduces the issue every time.
Any ideas? Feel free to laugh at me if there is no way in the world that the outside temp could have something to do with it. :) |
Are the fluid lines run through the oil cooler or possibly been rerouted and deleted the cooler ?
Originally Posted by Interceptor
(Post 4577784)
What engines and steering ? the hotter the day the hotter the bilge
(Post 4577790)
What fluid are you running in your steering? I assume you have a serpentine belt set-up. Is your belt set at the right tension? Maybe a kinked hose? Just trying to throw out some easy checks.
I reread your post. You said: Hydraulic oil. I run Dextron III
Originally Posted by fordf350
(Post 4577990)
Its a weird one for sure, fluid might be breaking down, marginal ps pump ?
Edit: most ps systems have an inline filter, you may want to check that also |
Are you running 1 or 2 pumps
| All times are GMT -5. The time now is 06:56 AM. |
