(Post 4610368)
No not on the 32’s. So when the motors are out take the silent choice off, put the blocking plates on and then make or buy tails.
It it would be a big PITA to go out the sides but if you do then Glass the transom holes up at that time. |
It will be plenty loud without silent choice and you can go dry tails which dumps the water through a separate bung. If you change exhaust hole location you need to be weary of rise of pipe as if it's not downward enough you'll pour water back into the motor. Just to be louder I would delete the silent choice and go dry tails
Originally Posted by I.C.U.Lookin
(Post 4610423)
If you have factory manifolds you'll need to replace. If they are performance you can get custom tails or extend yours
Sounds like a wet fart coming down the river
You want the exhaust exiting out the side of the boat, and above the water line?
| All times are GMT -5. The time now is 09:06 PM. |
