32’ Trailering
I’m considering a purchase of a 1994 32’ with twin 450’s. I’m concerned with towing it behind my Escalade ESV, MFG (Cadillac) states 8100lbs as capacity. Anyone know weight of the 32’ with twin big blocks on a triple axel trailer? Don’t want to buy a new tow vechicle if I don’t have to ? Any ideas ? |
32’ Trailering
From what I’ve read, it seems I need 10k + capacity. would like to hear from anyone that’s knowledgeable in this area. |
I am sure someone will chime in with actually weight. But I would start with the Trailer GVW rating. That will give you a ballpark. Disclaimer - I don't recommend towing anything that weighs more than your vehicles specified capacity. But, what kind of towing? A mile or two on a local road to the ramp or 20+ miles each way with stop and go and highway? Myself and many others move 35ish foot boats(example - 35 Fountain twin 496's) with full size1/2 ton 4x4 trucks. But its only local and occasionally(hand full of times a year).
Two big blocks = minimum of 3/4 truck as a general rule.
My 32' Fountain SFC which was a heavy model weighed 8,700 with 100 gallons of fuel. Adding a trailer puts you into the 10-11K range.
I have a 2000 32 with twin BBC and headers. 7,200LB dry weight, 130 gallon tank. Steel Myco trailer is 1800-1900 lbs.
Add fuel, anchor, life vests, cooler if you have in the boat, BS that seems to find its way in. Any of the modern 1/2 tons with a tow package would be fine, I think the Escalde may squat more then a little and kill the air suspension. |
I'll just leave this here.
I towed a 32 Sunsation from the factory to Metro Beach with a 1/2 ton truck and needed a 12-pack after arriving at the ramp. Truck couldn't get out of its own way trying to accelerate to merge into traffic. I towed a 32 Sunsation from LOTO to my house in Central IL (300+ miles) with my 3/4-ton D-Max and it was not until the last stoplight as I was entering town that I realized the dealership lied about making sure the trailer brakes were functioning properly (who needs brake lines to the rear calipers?!) as I had to make somewhat of a panic stop. Truck handled it just fine and the trip was a breeze. It's not a matter of what can be done. It is a matter of what should be done to make sure you, your crew, and those traveling around you have a safe trip. |
Stopping your rig in a "situation" is the most important.
Originally Posted by Knot 4 Me
(Post 4678776)
(Post 4678804)
What 1/2 ton? Our buddy just got a 32 sunny ( beautiful boat BTW) and towed it home from the NE with his eco-boost with NO trailer brakes and said it wasn't bad. He has the max tow etc so just curious.
I personally think with a decent trailer (meaning has good brakes) the Escalade/Suburban will do ok... However, I would recommend adding a load stabilizer airbag set up to the Escalade/Suburban. Best $300.00 you will ever spend! But like others have stated, the bigger the truck the better. |
(Post 4678804)
(Post 4678823)
This was a mid-2000's Chevy Z-71 with a 5.3L/3.73's. Joe asked me to tow it to Metro as a favor for one of the Sunny rallies. Had no idea I'd be towing a boat that weekend. I think the newer 1/2 tons setup properly would do a way better job but still I like to have the better suspension and brakes of the 3/4-ton/1-ton trucks. I lost the brakes on an 8,000lb boat/trailer once towing with a 1/2-ton 6.0L Yukon Denali XL coming down the ramp/hill off of 72 to get onto 61 at Hannibal on my way to LOTO. Boat/trailer damn near pushed me thru the light at the bottom of the hill and the rotors were toast afterwards.
The tow rating on my Z71 half ton is 8500lb and I only occasionally tow my 25’ single Baja about 30 miles or so. It gets it done but I wouldn’t say it’s super comfortable. My next truck will be bigger. |
Towing with an underrated vehicle is fine until the accident investigation begins.
Originally Posted by Interceptor
(Post 4678847)
I mean does anybody on here know anyone that was in that situation? just wondering |
32’ Trailering continued
Wanted to say thank you to each of you for your responses, this has really been helpful. You are all awesome to take time out to respond, and some great experiences / education you’ve passed along. So what I’ve gathered from this in a nutshell, is there are things I can do to help improve stability using my Escalade, although a larger truck is likely a complete cure for my issue. Since the towing distance from storage to water is under 5 miles, I’m not sure it justifies the shiney new truck just yet. That said I’m thinking of a type of towing equipment called a weight distribution/sway control hitch (WD/SC) that can do a lot to improve towing safety when you're pulling a heavy trailer, especially one that weighs more than half of the weight of the vehicle towing it (the base weight of the Escalade is 5500-lbs). In addition to that adding the load stabilizer airbag set up to the Escalade, suggested by “Bajaholic” previously in this thread. (Thank you by the way) I’m not only concerned about just the “pure weight”, in towing her down the road. But concerned about that weight on the launch ramp...don’t want to drop a transmission or jack the drivetrain trying to get her out of the water..? Or turn the Escalade into a sub... Any additional thoughts on my suspension fixes or a suggestion not mentioned helpful...thanks everyone ! |
An equalizer hitch is a waste of money. For a couple of reasons, boat trailers need length and angles to load and unload a boat. Many times due to ramp angles will have a drop off and then a angle down.The equalizer hitch will bind, then possibly bend the trailer and likely your hitch. But most likely it will just come apart and the chains will drop off. (Seen it happen a few times) and they are designed for excessive tongue weight. A boat trailer rarely has this issue. The biggest problem when hauling a larger boat is the "Pogo Stick" (Flex) and you really just need to balance it out. Remember, boat trailers for anything over 29 ft generally have triple axle trailer. This too minimizes the bounce.
IMHO, The airbags will do everything you will need. Like I stated above, the tongue wait is minimal, I would guess you would only need to inflate the airbags to 20lbs or less to bring all the support you need. Two other suggestions for your Escalade, add a transmission cooler and MAKE SURE you have good brakes on the trailer. Personally for the trailer, I would add the electric over hydraulic rather than surge.... I know this is a few dollars, to convert, but believe me, that is a change you would never look back on! If you use your head and pull out slow, the truck should never have an issue of pulling out of the ramp. (I am taking into consideration you have 4wheel drive of course!) The issue will ALWAYS be stopping and ride down the road. It is all about the cost, but you asked what is the best, short of a new truck... |
Makes perfect sense...I did check out the test done on you tube regarding weight distribution vs air stabilizer. If you haven’t I’d like to get your feed back. I’m no expert, which is why I’m here in search of answers. So I do appreciate it immensely. So I have the auto air leveling on the Escalade now, is that scratched when installing the air system you mention, or on conjunction with it ? |
BTW...it is all wheel drive |
Not sure what year your Escalade but i have a 2010 Avalanche (basically the same truck made into a pickup) i installed the airlift 1000 bags in my rear springs to help with my autoride system https://www.airliftcompany.com/shop/60769/
I actually blew up my compressor and both shocks once when i overloaded the bed of my truck with some Honey my dad got shipped to him from Arizona! Im not sure how much weight it actually was but the truck was a low rider! Compressor kept going and couldn't level off (this was before the bags) stopped working on the ride home cause it overheated and locked up...the shocks had pinhole leaks all over the place. :( very expensive lesson! :mad: Anyway the airlift bags do help. But if you have them inflated then the autoride wont work right if you don't have a load on the truck...i keep mine at around 10psi when not towing and pump them up after i hitch up and before i start the truck up. Granted I'm only towing a 22' boat on a dual axle trailer but it does help quite a bit. With proper brakes on the trailer i don't think i would have an issue going short distances towing a "PROPERLY" setup boat/trailer....long hauls or sketch twisty roads...no way! And I've had one personal experience in the past when i had my 1999 crew-cab dually towing a 30' scarab on a 3 axle trailer in LOTO. I lost the entire hub/spindle/brake/tire assembly on one axle (which took out the entire brake system on the trailer since they were surge brakes) coming out of a gas station after topping the boat off with about 200gallons of fuel....had to go downhill down a tree lined twisty road to get to the ramp......needless to say by the time i got down to the bottom of the hill i think i was pale white...my legs hurt from literally standing on the brake pedal trying to slow the rig down and my front rotors were glowing cherry red and billowing smoke like the truck was on fire! Took me a few minutes to compose myself and i think the only thing that saved my rotors from warping into garbage was the fact i just installed carbon pads and cryogenic treated disks the weekend before! |
Just remember you will be towing around 2,000lbs over the Escalades rating. Transmission might also complain. Does it have a tow haul mode or can you take out of overdrive when starting up the ramp or from a stop?
I have a 32' and an Escalade and there is no way I would use it to tow that boat. That boat and trailer is over it's rated weight limits. Besides that, older ones do not even have a selectable transfer case with low range so getting out of steep ramps may not be easy on it.
DEFINATELY DO NOT use a weight distribution hitch. The chains on the distribution weight bars WILL adversely effect the surge brakes in that they WILL NOT work. Also I would recommend as stated before 3/4 ton truck or better. I had a 1/2 ton Surburban towing my 34' Scarab. Had to find an emergency out twice. That did it for me. Got an Excursion and never looked back.
Yes it’s a short distance and it will probably will handle it but I would not do it. You get in an accident and cause a fatality, a prosecutor will use the under rated tow vehicle against you. Also like someone else mentioned, without the selectable transfer case, your Escalade will be overworked pulling it out of the water up a steep ramp. Buy an old beater 2500 gas truck and save your Escalade. |
I used a WD htich with Surge Brakes on a BARELY adequate tow setup years ago. It worked for about 2 seasons, but then I upgraded to a dually, and eventually got a Myco with EoH brakes as well.
After reading many responses, and considering the risk involved ...looks like I’ll be reconsidering using the Escalade entirely. Forcing it to happen could lead to real trouble. Thanks everyone for your time and much valued opinions ! |
When I had my 32, on a steel C-channel trailer, half a tank or so ready to go to the lake it was around 10,500lbs on the scales.
Just an update
I have used 1/2 to. Dodges with the Hemi and 8 speed transmission with a 3.92 gear in the back .....it pulls great , and actually stops well ....now the truck is setup from factory to pull 11,900........
Just would like to advise that Wake Zone made me sign a waver that my expedition was rated high enough from factory 9k. I towed my 32 with it with no problem.
Rich |
| All times are GMT -5. The time now is 08:40 PM. |
