Try a Hydromotive P5X. That’s what Tom Bucknell, the owner , recommended, Generally, more blades have better hole shots and higher cruising speed. Your slip is real low and you may already have your best prop. You might try trimming the boat a little more. 690 HP should push your boat a little faster than 78. |
| All times are GMT -5. The time now is 07:45 PM. |
