-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Stress cracks or more serious (https://www.offshoreonly.com/forums/fountain/359841-stress-cracks-more-serious.html)
Walter Sobchak 03-30-2019 06:02 PM
I looked at a 27 fever today that had what appeared to be cracks/stress cracks on transom where hydraulic sterring attached as well as cracks on hull under motor. Should I be concerned?
https://cimg3.ibsrv.net/gimg/www.off...61cdfeb610.png
Tinkerer 03-30-2019 09:56 PM
The transom is most likely very wet and will have to be replaced. I have never seen stress cracks on a healthy transom.
oconnor marine 03-31-2019 04:34 PM
I have seen cracks like that in gelcote that is non structural and structural. Poor quality gel formulation. Common in older boats . Gelcote will flex without cracking to a degree.
Walter Sobchak 03-31-2019 05:21 PM
This photo is the hull. I don’t have a photo of the transom, but there’s cracks right at hydraulic steering attachments as well.
TexomaPowerboater 04-01-2019 12:52 PM
I'm not a fiberglass expert, but yeah I'd be concerned enough to keep looking for something else.
thirdchildhood 04-01-2019 03:48 PM
That would scare me away too.
Walter Sobchak 04-01-2019 05:24 PM
Thank you for responding. It’s unfortunate because the boat is beautiful. Search continues
RaggedEdge 04-03-2019 05:14 PM
If the boat is otherwise one you would consider then take things one more step and have a moisture test done. Then base how you proceed from there on the results. Might even ask seller to cover the cost or share in the cost in some manner.
