-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Hydromotive mounts (https://www.offshoreonly.com/forums/fountain/361435-hydromotive-mounts.html)
Cole2534 06-24-2019 03:13 PM
Hydromotive mounts
What parts do I need to run switch from a Bravo 1 prop to a Hydromotive? I've not been able to find clear documentation on it.
Thanks, Cole
Bama 06-24-2019 03:34 PM
The hub insert is shorter on the hydromotive. You can purchase just the insert with the round rubber pieces. The insert for the bravo is longer and the hydromotive prop will not tighten up if you try to use the insert out of the bravo prop. I went from bravo to P5X hydromotive.
Cole2534 06-24-2019 03:53 PM
I'm looking to mount a Quad-IV.
Got a part number?
Bama 06-24-2019 04:03 PM
Steel Drive sleeve 850821Q12
Cole2534 06-24-2019 04:24 PM
Boom! Thank you. I still haven't been able to get them on the phone.
