-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   42 big step with 6s that run over 100mph (https://www.offshoreonly.com/forums/fountain/366573-42-big-step-6s-run-over-100mph.html)
prostockcat 05-27-2020 06:32 AM
Curious on the ones out there how the water pickups are set up? I’m having some porpoise issues accelerating after 98 mph. I have a strong feeling I’m disturbing the water off the back of the boat. Let see some pics. Thanks !!
Unlimited jd 05-27-2020 07:07 AM
Adrenalinejunkey’s has 4 pickups. 2 for engines 2 for chillers. Pretty standard install, either side of center line.
prostockcat 05-27-2020 07:20 AM
That’s what I have also. Just checking on location.
Reggie Fountain 05-28-2020 01:08 AM
https://cimg1.ibsrv.net/gimg/www.off...048985a4fd.jpg
This is how we did them on the new Fountain with big power.
https://cimg4.ibsrv.net/gimg/www.off...cbc261acc9.jpg
New 47 with big power.
prostockcat 05-28-2020 06:24 AM
Im identical to that. I also have 2 pickups for the chillers on either side of the drain plug. What would cause this thing to lift and break the prop bite at over 100. Spins 17x33-15 rake
Unlimited jd 05-28-2020 06:27 AM
What’s the propshaft height?
prostockcat 05-28-2020 06:48 AM
3” above bottom 18.5” apart
Unlimited jd 05-28-2020 07:01 AM
Bigger diameter wheels
prostockcat 05-28-2020 07:50 AM
The drives are to close they will contact each other
Unlimited jd 05-28-2020 07:59 AM
Going to have to space down. But I’d think you could go to 17.5”. If the drive are moving 1” something is loose.
