one drive goes 1/2" lower than the other
I have one bravo x drive that trims down 1/2" more than the other, Is there an adjustment somewhere to adjust how far the trim will allow the drive to go?
There is a spacer that resembles a celery stick at where the trim cylinder pin passes through the upper unit, the proper position for the spacer on a bravo 1 drive is on the front side of the pin
You may have one of them in the wrong position |
Originally Posted by JaayTeee
(Post 4744476)
You may have one of them in the wrong position Both spacers are in front of the pin, an other ideas |
Depending on if the transom assembly was replaced look for the limit blocks
https://cimg3.ibsrv.net/gimg/www.off...e6dae400a4.jpg Could also be a previous version of the cylinders which a bolt and spacer was used https://cimg9.ibsrv.net/gimg/www.off...02e445cc8c.jpg |
