-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   96 fever gas gauge while on water (https://www.offshoreonly.com/forums/fountain/368503-96-fever-gas-gauge-while-water.html)
9627fever 09-14-2020 03:47 PM
96 fever here...all new sending unit and gauge...fuel level stays on full while on the water...the very minute she goes on the trailer gauge reads a pretty accurate level ..
Crude Intentions 09-15-2020 02:40 AM
They sit vastly different in the water vs on the trailer.
RaggedEdge 09-17-2020 04:46 PM
Fountain fuel gages have always been a mystery. To start with they are cut to match the V of the hull, means the lower they go the more they are off. They sit mid hull, that means they are very effected by balance on a trailer. In very simple terms LEARN YOUR BOAT. When mine says 1/4 fuel I need to be looking at a fuel pump real close by.
zz28zz 09-18-2020 08:19 PM
Yep, sender is close to rear of tank, so when bow is up (i.e. in the water) the fuel runs to the back of the tank. Perfectly normal for a Fountain (and other makes with similar design).
Once I see 1/4 tank on the water, I'm headed straight back to the ramp.
