700sci issues >
700sci issues
700sci issues
Old 06-09-2021 | 03:50 AM
Default 700sci issues
I’m having problems with my 700s shifting from neutral to reverse and shutting down can’t seem to isolate the problem… I have Latham stage three system with whipple super chargers. Any ideas ?
Gofast42 is offline
Old 06-09-2021 | 09:40 AM
What is Latham Stage Three System? You mean Whipple Stage Three?
When I had problem with my mine dieing when shifting, it ended up being a trans cable binding up - which prevented the shift interrupt switch from fulling switching. You can try disconnecting that switch as a trial, but Mercury wants it there - probably to protect the weak NXT transmission. Some people run with the switch disconnected - but it's likely there for a reason.
ALL_IN! is offline
Old 06-09-2021 | 12:21 PM
Whipple with Latham electronic controls .. still throwing parts at it .. Throttle positioning sensor .. new throttle cable… Re map computer.. everything seems to be operating correctly and within spec. Absolutely frustrating.. starboard did it last season and the tps solved it.
Gofast42 is offline
Old 06-09-2021 | 12:29 PM
F-2 Speedy's Avatar
when you say shutting down, are they stumbling and die when put in reverse ? is this a 700 NXT package.....need to know more about the boat drives and wheels
F-2 Speedy is offline
Old 06-09-2021 | 03:58 PM
Yes it’s the nxt package.. Neutral to reverse and then dead. No stumble … it’s now not doing it as often but still doing it. Occasionally it will die in Neutral.
Gofast42 is offline
Old 06-09-2021 | 04:04 PM
F-2 Speedy's Avatar
Mines not exactly the same set up, but same symptoms a year a go, would die going into reverse off the trailer, replaced both the IAC 's and it stopped
Old 06-09-2021 | 05:33 PM
Try replaced that too.. grrr
Gofast42 is offline
Old 06-09-2021 | 08:58 PM
Thank you F-2 Speedy…
stil trying to figure it out.. will post when I do..
Gofast42 is offline
Old 06-11-2021 | 09:15 PM
Thanks F2-Speedy
Gofast42 is offline
Old 06-11-2021 | 09:20 PM
After throwing all kinds of parts at it it's better.. keeping the drives neutral at the dock seems to help to. Livable but have to pay attention If the wind is ripping and have wave action cause if it dies no power steering
Gofast42 is offline
