Freshwater Flush
Using the optional freshwater flush from Fountain does anyone have the direction sheet on how to position the faucet and lever for running and for flushing? I thought I had a pdf but can't find it.
Thanks in advance. |
Faucet valves open for running closed for flushing. Gate valves should be marked flush Open/Closed.
My gate valves aren't marked but once you know how to do it, it's pretty simple. Hook up the flush hose in the bilge, open the gate valve & close the round handle faucet looking valve. This will flush the motor through. I also open the faucet valve & let that flush out the drive after the motor is done. Just remember to close all of the gate valves & open all of the faucet valves when you put it back in the water.
Any pictures of setup??
Need a flush system for twin 454 29 fever
| All times are GMT -5. The time now is 04:18 AM. |
