-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   2003 Fever 29 prop pitch (https://www.offshoreonly.com/forums/fountain/376579-2003-fever-29-prop-pitch.html)
techman 08-02-2022 07:25 AM
If you go down to a 26 you are going to be all over the rev limiter with that setup. You will probably get on plane faster but the setup you have now sounds spot on from a performance perspective.
Have everyone move to the cabin when taking off.....maybe that will help pop you up faster?
RaggedEdge 08-02-2022 04:30 PM
Originally Posted by jim2826 (Post 4840220)
5800 rpm
Are you sure on this? The 525's are limited @ 5400, unless they have been reprogramed.
Scarab28 08-22-2022 09:28 AM
I run 78 at 5200 rpms with a 28 B1. You should be upper 80's at 5800.
DallasBAJA 08-22-2022 01:53 PM
Im assuming this is legit GPS speed?
Scarab28 08-22-2022 02:21 PM
Yes.
DallasBAJA 08-22-2022 02:32 PM
Originally Posted by Scarab28 (Post 4842356)
Yes.
29 fountain fever with a stock 525EFI?
jim2826 08-22-2022 03:19 PM
Plaining with 28 pitch
Any suggestions on how to get out of the hole without dropping to a lower pitch prop. Just had my 26 re-hubbed and balanced ready to go on the boat.
jim2826 08-22-2022 03:21 PM
Scarab28 08-23-2022 08:15 PM
I switched from 28 b1 to 28 Hydromotiive 5 blade. Much easier to plane.
Brad Christy 08-24-2022 06:49 AM
Jim,
A Good Read
This might be a weird question, but are you sure you're getting what you think you should out of the engine?
Thanks. Brad.
(937)545-8991
