-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   2005 fountain 35 lightning x dimension.. (https://www.offshoreonly.com/forums/fountain/379693-2005-fountain-35-lightning-x-dimension.html)
Reggie Fountain 06-27-2023 04:23 PM
The herings are going to be alittle faster, but a set of mercury maximus 5 blades will be your best bet.
Rufus81 06-27-2023 05:33 PM
I read the diffuser comment, but I guess I just had drive spacer in my head. Lol. Being on the lake of the Ozarks, even if it will run low 90’s with a little lower x and get on plane better, I will be happy. Not many times you get to do a full speed rip at LOTO. Just curious, what’s some of your guys cruising rpm at say 3500?
greg800le 06-28-2023 11:09 AM
Here is the Fountain test sheet for a 2005 w 525s, standard bravo XR & 32” bravo props.
https://cimg1.ibsrv.net/gimg/www.off...bdd8ec961.jpeg
The boat will cruise 50 mph @ 3400 rpm with a full tank & fully loaded including the Bimini top up (but closed)
techman 06-28-2023 12:09 PM
QUOTE: Here is the Fountain test sheet for a 2005 w 525s, standard bravo XR & 32” bravo props.
The OP's boat has a 20" X-Dim. Weird....must have been playing around with the height on supercharger boats.
I'd definitely go with a spacer to keep it simple. Why Frankenstein a prop when you just might need to replace one later you can go off the shelf.
Rufus81 06-28-2023 01:42 PM
https://cimg0.ibsrv.net/gimg/www.off...e2147e89a.jpeg
Here is my sheet. As you can see, it ran 91.5 even with a really high x.. but if my prop slip is too much that could potentially cause that would be my guess.
green lightning 06-28-2023 03:10 PM
With that test sheet Terry the test driver should have seen that there was some sort of a problem that boat with 1150 total HP it should have been in the low 100's for MPH
Rufus81 06-28-2023 03:20 PM
I will hopefully know what these 1.5” spacers do after the weekend. I will let you guys know. 90-92 would be more than fine with me.
Rufus81 06-29-2023 07:42 PM
Boat was just ran it with the 1.5” spacers. Gets on plane way better. Haven’t topped it out but 86.2 gps briefly running up to 5-5100 rpm’s. Still has quite a bit left in her. I am sure it will probably touch 90.
techman 06-30-2023 06:54 AM
With the Herring's or Bravo's?
Rufus81 07-01-2023 09:07 AM
Bravos.
