-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Encapsulated Stringers (https://www.offshoreonly.com/forums/fountain/380483-encapsulated-stringers.html)
cprperformance 09-06-2023 07:26 AM
Can somebody please tell me what Encapsulated Stringers means. I am currently looking for a Fountain Lightning to purchase and I come across this term quite often. How do you encapsulate stringers? Hopefully this doesn't mean covering up rotten wood!
techman 09-06-2023 08:11 AM
In super simple terms, it means that the wood (or other material) stringer is covered in fiberglass. Sounds like a no brainer for moisture abatement, BUT, if the ends of the stringer and any holes cut into them aren't sealed, then problems occur.
Moisture readings by a pro or drilling into the stringer are the only way to truly know what's going on in there.
cprperformance 09-06-2023 08:35 AM
Right, so aren't all stringers technically encapsulated. I have never seen a bare wood stringer!
techman 09-06-2023 08:40 AM
Some have just bare wood, paint, resin, or epoxy. Fiberglass is the most labor intensive.
Wildman_grafix 09-06-2023 09:12 AM
I have seen that on cruisers a lot.
greg800le 09-09-2023 11:02 AM
I believe that Fountain switched to foam encapsulated stringers in 2005. Perhaps someone can confirm if this is true and if all models were affected.
Midwestcruiser 09-11-2023 05:04 PM
Reggie Jr. stated on this forum that they started composite stringers in 2005 like you said.
