31 TE Top speed Twin 250XS
What should I expect to see for top speed on this boat propped correctly?
Mid to high 50’s. My best friend has a 31 TE with 250 verados and it will go 57.
Originally Posted by Stuckonstupid
(Post 4937005)
Originally Posted by tunlcat
(Post 4937010)
Well then Im doing good I suppose, I get 62-63 GPS currently on the limiters at 3/4 throttle with 22p bravo1 props
I'd say if you are on the limiters at 3/4 throttle, you need more prop. Try 24P Bravos. Thanks. Brad. |
WOT rpm range for 250xs is 5600-6200rpms from what I can find. Rev limiter should be 6350. If you are there at 3/4 throttle you should be able spin 26's. Each inch of pitch is worth about 200rpms when using the same make/model prop. BBlades does have a test program for props.
| All times are GMT -5. The time now is 07:24 AM. |
