Cooler drains where??
32' Fever with the cabin built in cooler. It appears that it just drains into the boats hull? At least there are only 2 thru hull fittings up front, 1 for sink, 1 for bilge pump. Correct? What a piss poor design. Trying to eliminate all possibility of water in hull bottom. That can't be all that good.
Thinking if it does just drain into hull, then may try to tee into the sink drain hose and use a check valve. Really don't want to install another thru hull fitting. |
Mine drains down the port side. You would think Fountain could have made the drain hose long enough to drain into the bilge. :rolleyes: I usually bring a separate cooler with me. I use my Ice box for storage. Ice packs are a much neater if you do want to use the Ice box. You just have a little condensation to deal with.
Dan |
| All times are GMT -5. The time now is 06:25 PM. |
