-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   496 HO Mag - Need help! (https://www.offshoreonly.com/forums/fountain/54939-496-ho-mag-need-help.html)
Alli-Runner 07-20-2003 09:37 PM
I have a 2004 496 Mag Ho. I am having propblems with all the soot that flys up on my swim pad. It's ruining the vinyl. I can't get it clean and it only stains the left side. My boat is a 27 Fountain and have already had one cover replaced due to the soot stain from this motor. Anybody have any ideas to clean the motor and the pad?
candyman35 07-20-2003 11:53 PM
You may want to have a Merc Mechanic check the engine out. What octane gas are you running? If you run a higher octane than called for it could be one of the causes of the soot.
Dan
Alli-Runner 07-20-2003 11:55 PM
Only 87!
ROUGHSTUFF 07-21-2003 05:40 AM
I have twin 496 HO's and had the same soot problem during the first 20 hours. I have notice alot less soot after the 20 hours.
Alli-Runner 07-21-2003 10:16 PM
Mine has about 27 hrs and still is not letting up with the soot. Had local dealer call about the problem today and Mercury is sending me a leaned out computer to fix the soot problem. Will post update after this weekend on the new ecm.
olemissalum 07-22-2003 03:07 PM
Hey Alli,or should I call you "oil slick" now:D
Make sure you take all the old stuff off first before putting on the new computer;)
Raypanic 07-22-2003 04:56 PM
I don't know what you have tried to clean it with but I have had extremely good luck with "starbrite black streak remover", you can get it at any boat store. You may have to use a soft brush on the vinyl to get in the cracks. Could be a quick compromise.
