-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Don't try this at home! (https://www.offshoreonly.com/forums/fountain/61095-dont-try-home.html)
Fountainclimber 10-19-2003 09:40 AM
Too late, its already in. As soon as it warms up to 60 today, I'll go out and try it. It was alot harder than it looked to install because that hose doesn't bend much.
I recommend trying cheap brass fittings until you get it all sorted out and then switch to the stainless if you want.
There is no way currently to drain the strainer itself so I have to figure that out. CP has a 90 with a plug that might work.
I'll post the results.
FC
gferdon 01-20-2004 09:15 AM
ttt
Fountainclimber 01-20-2004 09:07 PM
1 Attachment(s)
One more cabin "adjustment". Does the flush handle on the porta pottie not clear the door? This is $7.00 worth of teak and the lid is still below the covering cushion.
