Shorepower
Thinking about installing shorepower this winter for the outlet in the cabin.
What is usually included on a factory installed setup on the 32' range boats? Is there usually a battery charger included in this or any other add ons? Has anyone ever installed this themselves? Thanks |
TTT
There is a fuse panel on the port side of the cabin just to the right of the cabin power switches. It has breakers for Air Conditioning, Fridge, etc. There is also a battery charger included in the shorepower package which is mounted next to the port side battery switch under the rear seat. There is also two outlets mounted right to the left of the cabin light switches. Mine was factory installed but there's not a lot to it. Cutting holes in the lexan and hull would be the worst part of the job. Let me know if you need pictures.
Dan |
Thanks Dan!
Not to worried about the AC or fridge :) but the battery charger sounds good. Didn't know if there was a panel or not since there is basically nothing but an outlet and charger. If you happen to have a picture of the panel, that would be great. But don't make a trip out to take one. Jerry |
1 Attachment(s)
Sorry it took so long. Hope these help.
1 Attachment(s)
2
1 Attachment(s)
3
Thanks again
| All times are GMT -5. The time now is 09:49 PM. |
