-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   blower pulley (https://www.offshoreonly.com/forums/fountain/66648-blower-pulley.html)
dykstra 12-18-2003 03:38 PM
blower pulley
I have a stock 525SC 29' Fever. What size pulley do I need to make more boost? The stock one now makes 5 psi. If they do make one, is it worth it?
US1 Fountain 12-18-2003 07:23 PM
For more boost, go to a smaller pulley.
dykstra 12-19-2003 09:04 AM
thanks, usa1 fountain
Back4More 12-19-2003 06:04 PM
1 Attachment(s)
If I remember correctly the blowers input shaft is splined.
Take a look, if it is you will either have to have a Machine Shop turn you one up or refit the snout with the standard Weiand shaft to use any of their pulleys.
I found a guy who made a bunch a few years ago but they were really small, like about 2.625" dia.
I tryed them but didn't like pushing them that hard, those were the only ones he had left so...
Let me check the garage cabinets...i think i have a few Merc takeoffs out there.
Maybe we could turn the dia. down on them.
I found them...They measure about 3.30" in dia.
The ones I went to when we upgraded shafts and pulleys was the 3.07"dia.
Which made just shy of 1lbs. additonal boost.
Back4More 12-19-2003 07:36 PM
1 Attachment(s)
Weiand pulleys...
carney 12-21-2003 10:36 AM
my 525sc had smaller pullies that made 8psi but ,the belt slipped at high rpm . I went back to stock 5.5 , I think the best way to go would be a intercooler also if you start playing with boost. heat is not your motors best friend. but good luck with what ever takes place.
