-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   where can halon bottle be filled (https://www.offshoreonly.com/forums/fountain/66904-where-can-halon-bottle-filled.html)
carney 12-22-2003 08:09 AM
Any one know where the big red bottle can be fix and filled? I had the motors out of my boat . The bottle sat in the shop for 30 days ,I put it in a spot where it would not get broke. My wife came in and dropped something on it and it went off. I thought she had shot me with one of my own guns. they make one hell of a noise. I called kiddie and they want $225.00 to refill.:confused:
SeaDated 12-22-2003 10:55 AM
If I'm not mistaken, they will not refill an aluminum bottle. Only the steel bottles are refillable. I found that out after mine went off invertinly. I had to replace the entire thing. I can't remember if the new one is Kiddie of Fyreboy but it's a red bottle good for 150 cubic feet filled with FE241. They sent me two...long story but it was to costly, so they said, to send it back. Thus I have an extra. I would love to make you a deal on it but I'm not sure how to get it to you.
dyno 12-22-2003 12:07 PM
I broke off the electical sender that I think turns the alarm on......anyone fix those???
carney 12-23-2003 07:21 AM
Mine is the big red bottle, What ever she dropped on it she broke that fuse link piece . I know I can replace that I see the fiters at work with the the same head. I must make sure the degrees are the same. but then must find some one to fill the thing. I have no Idea how you would ship them , with out getting hasseled . I may have to spend the big buck. As for the sending unit, I think all that does is tell the indicator on the dash that the bottle has pressure. I have disconnected the wires and put them together and nothing has happened, but the green light goes out. I do know that if you take the unit out yours will be empty like mine. there has to be some one that can recharge them other than Kiddie.
rouxsterre 12-26-2003 10:07 PM
It is illegal, under federal law to refill ANY Halon fire extinguisher.
FM200 or other Halon substitute can be used to extinguish a Class B or C fire.
