-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   HP525 Whipple Charged (https://www.offshoreonly.com/forums/fountain/70772-hp525-whipple-charged.html)
FastFountain35 02-03-2004 08:10 PM
procharge that thing,you only live once. :D :D :D :D steve got your pm. billy and i didnt go . he had to go to a horse show with the wife:( :(
502KC 02-03-2004 09:50 PM
29 Fever Whippled 500efi
My 2000 29 Fever, is Whippled on a stock 500efi. 100 hours on the whipple with no major issues (had 70 hours when whipple installed). Bit the bullet when the whipple went on, and went Imco Xtreme upper and XR internals on the lower. The drive is still alive as well. I am definitely not easy on it, but I do ease it out of the hole, and naturally pull back on the stick when she's aired out. If I have one gripe it is that I only picked up 10-11 mph. I know the drive took a little HP away, but probably need to do some prop dialing, labbing etc. Have dealt with Dustin Whipple on some issues, and he is easy to work with, and offers good advice. Overall, I am happy with the outcome.
nolimits 02-04-2004 07:45 AM
Thanks for the input 502KC!!
Finally info from someone who has done it.
Does Dustin Whipple tell you how much more HP you got out of your 500 EFI? Did you need other stuff (Fuel line enhancements, injectors, EFI modules)? Was it clear what you needed, do they provide written info? I have heard stories of guys buying some of, but not all of what they need and then having the motor blow...
I have a buddy running a Baja with a spec'd 830 HP Blower Sop Motor using a stock Brave I Performance. Three years of easy starts and not throttling up through turns and all is well.
502KC 02-05-2004 12:17 AM
Your welcome...
I was tossing around the idea of doing it myself, but ended up having a shop do it. I had alot of custom rigging done, like adding a strainer, larger fuel filter, all braided fuel and cooling hoses.
But, yes everything you need to do the job is provided. You have to send your computer to Whipple so they can reprogram it. Dustin emailed me the install instructions when I was contemplating the system. Shoot him an email, and maybe he can do the same.
As far as HP, the 500efi kit advertised 730. Never dyno'd so I really don't know???
Mark D 02-27-2004 11:00 PM
Well guys, here we go. No, not me but a boat that runs in my local circle.
39 Velocity with twin HP525's.
My Fountain/Velocity/Spectre/Nordic dealer is certified Mercury Racing so this will be interesting how this works, for you guys on the fence, including me..
They took this stock HP525/XR drive application, bolted shortys on the outdrives & got 87 mph.
Now the owner just ordered a pair of Whipple Chargers for the HP525s. Man they look killer. They are bolting them on this weekend & I will report back on the stats, the increase in speed, fuel, install time, etc.
They are hoping for trips on the GPS.
Fountainclimber 02-28-2004 07:18 AM
I just got the Vortech for my 500EFI. At first it looked like there was a million pieces but everything was in clearly labeld bags. I put the sub systmes together and it wasn't hard at all. I don't expect any real problems with the install.
The only thing the manual says that I can't do at home is cap upper water inlet on the header.
I just need to get the boat out of storage and start to work.
The installation manual is available on their web site. They have been very good on support so far.
I am going to do the head gaskets and valve spings when I get going.
I'll try and post pictures when I get started.
F
Mark D 02-28-2004 10:52 AM
FC-
Post the pics, that would be great.
I am sure you will have no problem because you are a true craftsman anyway.
gferdon 02-28-2004 12:57 PM
FC,
Refresh me here...the Vortec unit is the most compact of the popular superchargers, yes? Also, are you going to pull the engine for the install? I know everyone will be VERY interested in seeing the progress and finished product as PP says, you are a true craftsman! Good luck and what type of increases do you think you will net...the Vortec is a 5.0psi unit?
Gary
StrikinLightnin 02-28-2004 03:45 PM
How fast was was it running before the shorties were bolted on?
Mark D 02-29-2004 11:43 AM
SL,
I'll find that detail out & get back to you.
