Roger P
Roger, these are the hoses that you will need to replace the manifold-riser hoses if you wish to remove the tees on the manifolds.hose
I forgot to mention, you will need to replace the ALT belt too since it goes over the water pump. I "think" the PS belt is fine. If I remember correctly the WP pulley has a groove for a PS belt, but it is not used on your motor. |
Thanks for the info :D ,it is much appreciated
| All times are GMT -5. The time now is 07:31 AM. |
