-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Depth finder how to set (https://www.offshoreonly.com/forums/fountain/78058-depth-finder-how-set.html)
jeff bratton 05-01-2004 04:19 PM
how do you set the Graffrig depth finder? it keeps sounding off. Thanks Jeff
Downtown42 05-01-2004 04:35 PM
no owners manual? Sounds like your shallow warning alarm is set.
jeff bratton 05-01-2004 06:52 PM
no paper on depth finder. shallow alarm is going off, not sure how to set it. It was going wild in 100' of water. thanks Jeff
Downtown42 05-01-2004 07:33 PM
Mine never worked good. Transducer is epoxied into bildge. I read some where that you will never get a good working one due to the hull composites on Fountain unless you drill into the hull and thru-it. I have a Lowrance and sent the brain box to them, ck'd out fine so I bought another transducer and that did the same thing. :(
US1 Fountain 05-01-2004 07:34 PM
They default to 10 ft when powered up. Push and hold the little button in the center to adjust the depth setting and/or to turn on/off the alarm.
Downtown42 05-01-2004 07:36 PM
You should be able to hit alarm button to disable/turn off. Call Livorsi if no one else chimes in here.
50boat 01-26-2005 05:16 PM
Re: Depth finder how to set
:eek: :eek: yea mine does the same thing, and will not read when moveing more than 10 mph. it will read 100ft when only 3ft. and so on
