-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Air/Fuel Separators (https://www.offshoreonly.com/forums/fountain/80143-air-fuel-separators.html)
Fountaineer 05-28-2004 05:35 PM
Air/Fuel Separators
I read in a previous post that some of you were going to install one of these to help prevent fuel from spilling out of the vent when fueling, but I never read about the results.
Has anyone tried to use one yet?
RJ1340 05-29-2004 10:15 AM
Re: Air/Fuel Separators
What kind of weed you got out there in the land of fruits and nuts?
Downtown42 05-29-2004 11:13 AM
purple hairs
rjcardinal 05-30-2004 08:59 PM
I installed one it does the job. I used one I found at west marine. I installed it in the fuel tank vent line and it stops the fuel from comming out of the vent when the tank is full. Before it would spit a little out when I would fill up. Worse than that when I would pull away from the pump and look out my rear view mirror I could see a steady stream of fuel come out of the vent. Both problems are solved now. It will still spit a couple of drops out of the vent when filling the tank but thats it.
Ron
Fountaineer 06-01-2004 02:56 PM
I think I might want to try one, because everytime I fill up it seems like I loose two quarts out of the vent.
