small rpm problem?
I was wandering if anyone might know why that when i run my props turning in, the right motor laggs behind about 200 rpms but when i run them turning out, they both run dead on together. I called herring and they said it wasn't something with the props because if they run dead together turning out then they should do the same turning in. Any suggestions? Is 200 rpms even that much to worry about?
Re: small rpm problem?
that is the strangest thing..?
are u gonna run em in or out? |
I run them in all the time and the right motor kept lagging behind about 200 rpms and i had talked to some guys and they told me to switch the props and try them running out and if the left one lagged then it was for sure the props and well you know the rest. Pretty weird to me!
hmmm that is really odd
how was it spinnin out? handling wise? |
| All times are GMT -5. The time now is 12:29 AM. |
