-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Help needed with Imco shorties (https://www.offshoreonly.com/forums/fountain/80848-help-needed-imco-shorties.html)
Jonas 06-10-2004 02:19 PM
Re: Help needed with Imco shorties
they were 502's with merlin heads etc as per teaugue est hp was 550.
toolbox 06-10-2004 02:25 PM
Jonas,
Thanks for the input.
T.J.
Back4More 06-10-2004 03:46 PM
I would see what happens with some 28" B1's
Zanie 06-11-2004 07:08 AM
What is your prop height with the shorties?
Trim your drives so the prop shaft centerline is parallel with with the bottom of the boat.
Lay a straight edge on the bottom of the boat directly in front of the drive, extending back towards the drives.
Measure the distance from the bottom of the boat(directly in front of the drive) to the centerline of the propshaft.
What is that distance?
DS
Downtown42 06-11-2004 12:46 PM
JONAS, what was your top end on the '92?
Jonas 06-11-2004 12:47 PM
low eighteis
Marginmn 06-23-2004 04:33 PM
Toolbox, any progress with those imco shorties? I was thinking about doing a set myself.
stevedg 06-28-2004 11:19 AM
One of my boats was a 35 lightning and you will NOT get any speed even with extension boxes. The advatage that the shorties have is when your speed is in excess of 90 MPH. At this speed or higher you could expect to see 3-5 MPH over stock length drives. Also keep in mind that fountains have a very high x-demension already, the hulls are pretty much tweeked as much as possible at the factory.
