Broken Engine Area Lights
Besides replacing the same lights every 5 minutes, has anyone found a light that will not break it's mounting bracket in the engine area. Mine is a 1997 29 single.
Re: Broken Engine Area Lights
93 35 are original and bracket has never broke.
'96 29 - One broken and one not broken. Also looking for a good replacement idea.
Both of mine also broke at the pivot point.
I made new bases out of teflon. Look exactly like the originals but will not break since teflon is not hard and brittle like the original plastic. |
Any other ideas???
I'm swithcing mine over to the LED strip lights--found them at West and discount stores ofr boat trailers. They are 4-LED strips and totally sealed. They use significantly less current and seem like corrosion cna't happen.
Poorsche www.boatmat.com |
I just keep the hatch closed at night....
If you haven't broken those chincy lights from the factory
you're not running full out!!! :p :p :p I've gone through a few then switched to these............. :rolleyes: :rolleyes: :rolleyes: http://www.westmarine.com/webapp/wcs...235&storeNum=9 They kick azz :) |
Thanks Strikin those will work
StrikinLightnin, are these lights adustable like the stock lights, or are they stationary?
I spent some time looking for a replacement spreader light and found these in Apache and Pantera as well as some other race boats. They put out a lot of light and have held up well. |
Thanks for the help!
I have had the lights brake in our fountains also, A friend of mine just bought a 2003 29 fountain that has lights that do not have the pivit that the old style lights have ,and we replaced ours with the short style that the 2003 has. They do not have as much adjustment but they likht up the engine comp and do have a slight adjustable head. Although one of the new lights had a wire that came loose frome the factory, we had to take it apart and solider it back together but they work fine. The price is steep for what you are getting.
My friend made me a set of light bases that look just like the factory supplied Guest 412 lights except he turned them out of aluminum. A couple of other people saw mine and then wanted a set for themselves. He paints them white, but I had mine powdercoated ($14 to have them and my battery cover powdercoated). He put a slot in the bases so you don't have to cut any wires to install them. They actually look better than the cheesey plastic bases, and they have held up quite well. I've been trying to get him to make these and sell them, they are really nice!
How many upgrades/fixes have you done so far. Seems you are ALWAYS doing something. How about some pictures of all this work ? |
Originally Posted by rouxsterre
US1 - you ARE the man.
How many upgrades/fixes have you done so far. Seems you are ALWAYS doing something. How about some pictures of all this work ? I thought about taking pictures of the light bases, but in all honesty they look just like the originals, just not broken. ;) |
| All times are GMT -5. The time now is 10:03 PM. |
