Cup holders
Where can i find aluminum anadyzed cup holders to fit in stock location behind the front bolsters. Hole size is 2-7/8".
Re: Cup holders
Try Trick Marine, that is where I purchased mine, do not be surprised if you need to open up the currents holes a little bit, I had to with all 4 of the ones I replaced.
Re: Cup holders
Fountain uses a bastard size cup holder. All I have ever seen need to be opened to the standard 3"
Re: Cup holders
Is making the opening difficult to do? Or is it just filing?
Re: Cup holders
I used a roto-zip when I installed mine, not very hard.
Re: Cup holders
Re: Cup holders
Thanks for the info :D
Re: Cup holders
Someone told me to try and paint the fountain cup holders with an anodized spray paint. I plan on trying it this spring when I pull the boat out of storage.
Re: Cup holders
Seen it done to aluminum, looks like the real deal. Don't see plastic giving the same results.
Re: Cup holders
I used the spray paint on the black plastic engine/side vents until I get my CNC billet ones made. You first spray a base coat of metallic silver and then top coat with a translucent color. Mine turned out very well and held up last season so well that I put off working on the new ones. A lot of the auto parts stores sell the rattle can paints to do this with.
Re: Cup holders
What does a roto zip look like?I would also like to instal larger cup holders. Thanks.
| All times are GMT -5. The time now is 01:14 PM. |
