No power to Dash Panel
Ok mechanics,
Went to fire up the engines on the boat after winter for a run this weekend and no power to the panel on starboard. Port engine/panel fired up just fine. I checked the fuses under the dash and they were good. Called my mechanic and he said three weeks before he could get to it. I can't wait that long. Any suggestions would be greatly appreciated. |
Re: No power to Dash Panel
Had same issue a few weeks ago--was corrosion--green powder/slime on contacts in harness plug at engine that connected to the dash harness.
I've got MarinePower 454 EFI's but I'm sure all are similar--all the sensor wires on engine come together at a round or rectangular plug that connects to the harness that runs to the dash panel. I took mins apart and all the contacts were green--I sprayed them with CorroisionX and connected/reconnected several times and Voom Voom-- Good Luck |
Thank You!
That very will may be it. I will let you know. |
WHERE CAN YOU BUY CorroisionX AT?
| All times are GMT -5. The time now is 01:36 AM. |
