I need advice on a new trailer
I definately want triple axil
Who to look at what type of brakes electric or hydraulic what size wheels and tires This is for a 1990 Sonic 30SS Oh Yea,,...SALT WATER!!!!! Thanks |
Re: I need advice on a new trailer
Myco triple with electric over hydraulic, tortion axels, drive gaurd, aluminum, and a tool box on the front.
I have had very good luck and performance from our Mycos. I would say get the aluminum if you trailer and dunk all the time.I have heard pluses and minuses for the electric over hydraulic brakes.So I have had surge type.
I had a twin axle under our 1988 scarab panther. The trailer was rated at 10,000 lbs.. Our last boat 2001 358 had a triple axle rated at 15,000 lbs. When I spoke to Bill Tweede at Myco he said the dual axle was strong enough for our 358 but is said give me a triple axle.I have an other Myco under our new 386. I went with steel all three times because I don't dunk the trailers that often.When I needed parts for the trailers Myco was great to deal with. Tom |
Get the electric over hydraulic disk brakes. They work. Joe Murray
Owens & Sons of St. Pete. Best cat trailer (IMO).
Originally Posted by License To Thrill
Pure why do you think you need a triple axle trailer? Two will do just fine. The center tires don't do anything but scrub off rubber in turns and add weight.
Kodiak Disc Brakes, they aren't cheap but if you get the stainless ones you won't be disapointed. Either Surge or electric over hydraulic, your choice.
Good point. I haven't had that happen so it didn't occur to me. I have a triple axle trailer myself but will have a twin axle aluminum trailer built. It will have torsion bar suspension, four wheel disk brakes, electric over hydraulic brakes and LED lights.
Kendall is the king of the LED's. Check into the hub set-up I was telling you my new AMT trailer has. The entire hub (bearings and all) can be replaced with one nut. |
Get a Myco, plain and simple, I got mine and promptly put about 1800 absolutly trouble free miles on it. that peice of mind was WELL worth it!
| All times are GMT -5. The time now is 07:33 AM. |
