Which octane fuel do you use? >
View Poll Results: Which octane fuel do you use?
87 octane (regular)
44
23.78%
89/90 octane (plus)
27
14.59%
92/93 octane (super)
97
52.43%
AV/ other or Allan 4 is a putz
17
9.19%
Voters: 185. You may not vote on this poll
Old 04-11-2005, 08:18 AM
21 and 42 footers
t500hps's Avatar
Default Which octane fuel do you use?
I have always used high test fuel, but with rising prices I may have to reconsider. With a pair of factory 502 mag/ 415's what is the recommended octane? I assume 89/90 will be fine, just looking for feedback.
Russ C.
t500hps is offline
Old 04-11-2005, 08:29 AM
Dean Ferry's Avatar
Default Re: Which octane fuel do you use?
Russ,
I use what Mercruiser recommends for the 502 MPIs, 87 Octane. Anything else, I'm told, is a waste of your money.
Dean
Dean Ferry is offline
Old 04-11-2005, 08:32 AM
JC Performance Engines
Stormrider's Avatar
I'm not sure what you have to use, but I must use 93 this yr.
Or I'll blow a piston.
Stormrider is offline
Old 04-11-2005, 08:34 AM
GLH
GLH's Avatar
When I had 502 magMPI's I used 87.
Now in blown mills 93
GLH is offline
Old 04-11-2005, 08:39 AM
OldSchool's Avatar
If I could use 87 I would....but I have to run 93 in mine.
OldSchool is offline
Old 04-11-2005, 08:43 AM
RollWithIt's Avatar
Use 87 octane in mine. Benefit of factory 454 mag.
RollWithIt is offline
Old 04-11-2005, 08:49 AM
Diamond Member #001
C_Spray's Avatar
600hp/540 ci Innovations - 89 octane, but knock sensors will allow me to use 87 in a pinch.
C_Spray is offline
Old 04-11-2005, 08:51 AM
Rough Seas Lie Ahead
Reckless32's Avatar
You have to remember the higher the octane rating, the "slower" the combustion burn. Normally large bore/stroke engines require a slower burning fuel/air mixture for the longer stroke of the pistons during combustion. A faster burn or ignition for the shorter strokes. A common myth is that the higher the octane you put in, the better/stronger your motor will run when in fact the opposite is true. You should only use what the manufacturer tells you, which in most cases is 87/89. In automobiles you could void your warranty if you don't use the recommended octane rating. IN the "old" days it was thought using the higher octane was best because the the hot cars of the day required it with their big blocks. So the urban myth of well if it's good for them then it's got to be good for the ole family car. Not true.
Reckless32 is offline
Old 04-11-2005, 08:54 AM
Chris288's Avatar
04 496 H.O.,, 87 only.. 01 5.4 f-150 87 only,,,, 01 nissan maxima 93 or it runs like Chit...
Chris288 is offline
Old 04-11-2005, 11:17 AM
DiabloFemina's Avatar
Depends on your compression ratio (naturally aspirated) or boost level (blown).
If you're running a CR of 12 or higher, I'd definitely run premium. You can get away with 87 under low load and cold air temps, but once you put the engine under load and or hot air temps, detonation is likely.
Same is true for even moderately blown engines. 90+ degree heat and even 4-6 psi means you'll need 93 or better.
Just remember, you can always limp an engine home if you can't find premium fuel, but be wary of hard acceleration (high loads) on the engine and temperatures. Detonation is hell on pistons.
This all assumes your timing is in tune, advanced timing will make the problem worse.
But like said above, a properly tuned engine, at 11.5 or lower CR, you're basically wasting money if you go with premium fuel (unless it's like 110 degrees outside and no humidity)
DiabloFemina is offline
Quick Reply: Which octane fuel do you use?
